does the switch work?
broken battery terminal in the drill?
I don’t actually know yet. Mustering the motivation to go out and have a play
ive had a quick google, could be battery contacts
these are pretty simple when you get into them nearly always repairable
An antique 9.6v Makita. As used by plasterboard fixers. They are indestructible. Pretty sure that it will work straight after you remove the furry green corrosion from the battery socket in the drill.
I've got one of those that needs a home at cost of postage if you can't get it working.
Drill that is not non-conductive chick
Chuck does not normally need to come off to get the case apart? 8 screws in the pic.
