I didn't think of thatif your spring has sheared near the tang? can you just bend it a bit and make a new tang for it?? common failure point on rotary return springs on pillar drills.....
rescued many a quill return spring this way as long as its not gone too far??
. I'll give it a try later.
That was another think I was going to ask, how do I remove the quill? The bearings don't feel too smooth so I wanted to have a look at them, clean them and replace if they're too far gone.If it's a spiral torsion spring you may be able to buy a length of the material, remove the quill and use the star wheel to wind the spring.
This worked perfectlyif your spring has sheared near the tang? can you just bend it a bit and make a new tang for it?? common failure point on rotary return springs on pillar drills.....
.This worked too, thanksdepending on what you got...................................pull the pinion out, the quill should then come out the bottom easily
), reassembled, regreased and repaired the spring. It all works perfectly now, I just need to make some pulleys.
