BrokenBiker
- Newport, South Wales
So in new year I'll be after a plasma cutter, mag drills and a shrinker/stretcher...got a bead roller on the way as a Xmas present, which with the shrinker stretcher should allow me to easily make some parts for a bigger project I have planned to start next summer if all goes well.
The plasma and shrinker/stretchers aren't an issue, I know what I want but I know 10% of bugger all about mag drills so my questions are as follows
Do they need to be mounted on something as big or bigger than the mag base, or could they be used for example on some 50x50 box to punch a decent hole through both sides?
Does brand matter? It won't get a massive amount of use, but for large holes my pillar drill is too fast for anything bigger than about 12mm and it bogs down with a step drill above 20mm...plus getting a 4 meter length of box into a 3 meter long shed is a faff and this is the main reason for wanting a mag drill really, portability and easy of putting holes in the middle of long sections...I have maybe a meter 1 side if the drill and 2 meters the other side which limits me hugely for this sort of stuff.
Finally, can you use normal drill bits with them or is it just specific cutters? Not a deal breaker if it's only specific cutters, but potentially be nice to use my cobalt bits as well as possibly using hole saws
