Evening lads
Looking at getting a mag drill, I've seen an evolution 28. Which cuts holes upto 28mm surprising enough.
So what's stopping you putting a larger sized cutter in the chuck/shaft?
Or is it the size of motor capacity??
My mag drill is rated at 35mm max but handles a 45mm with lots of coolant and a bit of care. Usually it's the speed that's the issue, the motor won't bog unless you're really taking the pi$$.
