grind a groove in the bearing shell with an angle grinder and shorten the pinIt’s a motorbike gearbox bearing, some have pins in to stop the bearing rotating.
Dremel drill press would work. Never heard of such a thing! I thought you could make something out of thread bar so that one turn is a known depth because of pitch. If that makes sense.I’ve got a dremel and a die grinder, don’t think I’ve got a small enough burr but it’s worth a go. Thinking about it, somewhere I’ve got a dremel drill press, that’d keep it all nice and straight, hmmmm worth trying on some scrap bearings first.
grind a groove in the case too and use a pin as a woodruff key , depending on the case and what holds it all in place ,,,, or locktite bearing bondgrind a groove in the bearing shell with an angle grinder and shorten the pin
If you don't clean it down properly afterwards that's on you.cant beat having a load of carborundum grit in the chuck and all over the saddle etc![]()
i wouldnt even do it in the 1st placeIf you don't clean it down properly afterwards that's on you.![]()
Only time I had to grind on my lathe I taped polythene up to protect. Still have it a clean down but protected the worst.If you don't clean it down properly afterwards that's on you.![]()
Which lathe was that?Only time I had to grind on my lathe I taped polythene up to protect. Still have it a clean down but protected the worst.
Never used the L mate. Cut the belt off to strip it for the van and never fitted it again.Which lathe was that?
Asking for a friend…..![]()
Though it's a doddle to pull the TS apron etc off the L for a decent clean down if I did.Which lathe was that?
Sure you can,I like it in my pantscant beat having a load of carborundum grit in the chuck and all over the saddle etc![]()
yea evostick is getting difficult to get in a carrier bagSome days I do think you've been sniffing the brake cleaner!
Me or brightsparks?Some days I do think you've been sniffing the brake cleaner!
@SparkUK what bike is it for?
I found this.
