Yes, had to zoom in to take a pic of the shank or you couldn’t see the marking.are they spiral flute?
I didn't look carefully at the coding.
It was very tight, when I screwed it in, but I unscrewed, it to check I had the right thread, which I had.
6g lowercase would be external.6H is a medium fit for internal - 6G would be the equivalent of external - usual general purpose.
British Standard set all this out - together with drill sizes for tapping and clearance (which some of the standard details in a few 3D CAD systems don't follow and get wrong!). They also set out run-outs for internal and external threads, as well as undercuts etc. If I'm designing something, I'd try to allow sufficient run out to avoid the need to use plug taps. And if it makes no difference to the operation of my part, for the sake of a few millimetres, I'll run holes clean through, even if I don't do the same with the thread. Just makes making it quicker and helps prevent us finding swarf stuck in blind holes when something fails when the machine is in operation.
We would usually specify tapping drill for any internal thread to control what we get (ie not rely on someone thinking "that'll be right . . "), but we are more often using roll/forming taps inhouse, so its gets a bit more complicated - our parts could be made in-house or externally.
As well going looser to allow for plating thickness, we use looser threads when we also have a location diameter on the part - allows for some misalignment of the thread to the location, and allows the location diameter to position the part without the thread fighting it.
