W.olly
- Radcliffe, Manchester
Now my compressor is running sweet....well it runs smoother after an oil change and fires up still as some said it wont with out blowing a 13amp fuse as i used 10w40 oil
It is a Jetair J11 3hp, max 150psi 11CFM
Mainly for now it will be to do work on a small boat and sand down ( prep work )
I like MM ( i pass one everyday after work
) but unsure of the tool quality
I am looking at air lines and found this 9mm one, 10m should do me.
https://www.machinemart.co.uk/p/clarke-hvo10-10m-hi-vis-air-hose/
I am not much up on air tools etc but from what i read larger air lines are better and not to cheap pon air tools are better.
Now I am looking at this sander from MM but i see it says load air consumption is 14cfm but average is 5cfm, does that mean my comp will not run at full wack for long, well at all ?
https://www.machinemart.co.uk/p/clarke-cat136-professional-6-dual-action-rand/
Just to make it harder i have just seen these kits on ebay, low air consumption.
Or are they just cheap naff.
http://www.ebay.co.uk/itm/150mm-6-P...196479?hash=item1ead297dff:g:pz0AAOSwZQxW6YeK
cheers for any help
W.olly
) but unsure of the tool qualityI am looking at air lines and found this 9mm one, 10m should do me.
cheers for any help
W.olly
