I've just brought a LVLP gun. I'm spraying high build primer, I set the gun pressure to 22 psi.
When I spray for the first few seconds I get a reasonable volume of paint then I get less paint delivered. I've set the regulator with the trigger pulled. The pressure does drop significantly when the trigger is pulled, but down to 22psi as set.
I'm thinking that the viscosity is too high, the paint in the gun chamber being delivered then less as more paint has to get through the inner filter, or could it be the air plug at the top of the pot, or do I need to up the pressure ?
The supplier said i didn't need to thin the paint but I'm not so sure. Any advice would be much appreciated
