It might well, but why introduce oil into the system then try to get rid of it? You should have a filter too, the one Xtreme sell seems very good and not expensive. If you do get oil, water or both in your system it will affect your cut quality and significantly reduce your consumables life.PCL Dropout claims to remove 99.99% of water and 99% of fluids - so might take oil mist too.
The xtreme bog roll filter is very good for the money. Cartridges are less than a tenner so no need to be stingy with them.It might well, but why introduce oil into the system then try to get rid of it? You should have a filter too, the one Xtreme sell seems very good and not expensive. If you do get oil, water or both in your system it will affect your cut quality and significantly reduce your consumables life.
Likewise!The xtreme bog roll filter is very good for the money. Cartridges are less than a tenner so no need to be stingy with them.
I’ll be putting a refrigerated dryer in when I can afford it.
I wouldn't - and don't add more with a lubricator - but unless you are using an oil-less compressor, and especially a well used, worn one, you probably have oil in the air anyway.It might well, but why introduce oil into the system then try to get rid of it? You should have a filter too, the one Xtreme sell seems very good and not expensive. If you do get oil, water or both in your system it will affect your cut quality and significantly reduce your consumables life.
Or, you can add usually add a block with ports to take out an oil-free supply before the lubricator.Many commercial lubricators with air dryers are basically two blocks screwed together and in many cases the lubricator section can often be removed to leave just the air dryer section.
I have one, quite impressed with the reduction in dross after fitting itThe xtreme bog roll filter is very good for the money. Cartridges are less than a tenner so no need to be stingy with them.
My comment wasn't aimed at you, but at the idea of using a dropout to get rid of oil when you have a lubricator fitted instead of getting rid of the lubricator. I'll be fitting a PCL dropout too as soon as I have spare cash!I wouldn't - and don't add more with a lubricator - but unless you are using an oil-less compressor, and especially a well used, worn one, you probably have oil in the air anyway.
Dropout claim:
Dropout® offers an extremely high performance all-in-one solution. Its unique patent design allows the unit to efficiently remove 99.9999% of liquid (water & oil) and 99% solid particulate down to 1 micron at a wide range of flow rates without mains power or costly replacement filter elements, and once fitted, the ongoing servicing costs are ZERO.
Your typical filter/reg filters down 5 or 40 micron - so a Dropout sounds like it drags out finer particulate matter too. Admittedly, the older your filter/reg, the finer the level of filtration it will offer as it bungs up![]()
Just my two cents worth.efficiently remove 99.9999% of liquid (water & oil) and 99% solid particulate
