Hi I'm in the market for a new tig for welding thin stainless steel and inconel down to 0.5mm. I will also be doing some aluminium work too so an ACDC machine is required. I've narrowed my selection down to the ESAB 2200i TA24 or the Kemppi Mastertig MLS 2300 ACX.
My question is which machine has better low amp arc stability? They both have the same current range so I'm relying on someone's experience with these machines for any feedback on how they run at low amps. Also if the microtack function is all it's cracked up to be on the Kemppi unit?
Thank you in advance!
. Cooler as well? I'd replace the stif rubber lead cover for a soft woven cover, I have 8mtrs leads so only replaced the first 3mtr @£25ish
