£2500-3500 depending where you lookIll bet its expensive can you imagine the new original part price.
It cleaned way better than I was expecting too , granted its only the outside.
this is 0.7mm thick. No chance of welding it if it becomes much thinner.I noticed you had a sandblast pot in another post why didn't you use that
That pot is crap need to sell it, we’ve got a proper Hodge Clemco pot in the lockup.I noticed you had a sandblast pot in another post why didn't you use that
you probably don't use block paving sand thenthis is 0.7mm thick. No chance of welding it if it becomes much thinner.
Dear god no. I like my lungs.you probably don't use block paving sand then![]()
No idea, haven’t cut it open yetI think they are double skinned, what is the inner skin like!
that's why I make my own .mines copied of a Clemco mini pot. been making them for 40 years now think I have done 6 now and still have 2 the 3mm, jet one and the 6.0mm that runs on 90 psi at 90 cfm using 1.5mm copper slag grit it can skin u alive in no time at allThat pot is crap need to sell it, we’ve got a proper Hodge Clemco pot in the lockup.
This is ⅜” nozzle 110psi. I don’t know how much CFM the road compressor makes. Over 100 though.that's why I make my own .mines copied of a Clemco mini pot. been making them for 40 years now think I have done 6 now and still have 2 the 3mm, jet one and the 6.0mm that runs on 90 psi at 90 cfm using 1.5mm copper slag grit it can skin u alive in no time at all![]()
probs a 125 cfmThis is ⅜” nozzle 110psi. I don’t know how much CFM the road compressor makes. Over 100 though.
ive got a big choke grit valve of a clemco pot if you build a large oneI wish I could could convince the gaffer at work to let me build a blasting setup, bet I could do some damage with the two 420cfm screw compressors.
sorry op for deviating postgood grief .. i didnt pay that for my car let alone an exhaust ,, granted its not an M anything.£2500-3500 depending where you look
Yeah they were a £3000 option that could be ticked when you ordered one. Bet they're more than that supplied now if you can find a seller. Quite a rare option as you'd imagine!
Good luck, inconel isn't the easiest to work with
If you want to know if it is Inconel,take it to the local scrappy you`ll soon find out.Simple question - how can you tell its inconel. And what filler rods do you use?
