Hi,can anyone provide me with comments on either the Lorch 210 mig or the larger 252 M pro 240 volt machines,Iwish to use a 1mm solid wire for projects in steel up to 10mm thick.hootchiecootchie.
Lorch supplier posts on here so I'm sure you will get a response. The 252 will definitely do what you are asking here and more if you are ready to pay for it.
The MPro252 is a modified version of the 250 so doesn't come with the option to add all the features from it's 3-ph equivalent, unless Lorch have changed that now
Good pieces of kit but go for the 4 wheel drive option and gas saver torch...
Reading back at your original post re: 10mm steel and 1mm wire, you may need a higher amperage range MIG but sadly, I think, there isn't a 240V model from Lorch above the 252, they're all 3-ph
Hi,matt thanks for more details re 10mm steel, spray sounds fine. I am in ARBROATH IN SCOTLAND , ARE THER ANY LORCH DISTRIBUTERS NEAR ME?.Hootchiecootchie.
