First off, hello everyone and if there is something wrong with my reasoning or anything please do say so. I am still a little lost so there are not many questions, but any helpful insight or anything beneficial said would be greatly appreciated. Also, sorry for the need for plugs and voltages that work in the states.
I have been reading these forums a lot (btw, great job with them. The best resource for welding that i have come across) and have finally pushed myself to tig. I have never welded before but i think it would be easier to go from tig to anything else (except maby o/a) than the reverse. I would like some help picking a welder and making sure i can hone the skills necessary.
First question, how have most of you learned to weld; night classes, friend, job? Once I start I need to know that I am doing it right, so how have all of you done it?
Next question you will need a little more background but here it is, which would be better, the newer inverter technology, or the old transformer tech? I am looking for a welder that I can use the rest of my life (in college now) but I will be moving a few times probably. I do not know how much access I will have to a 220v so the option of a 110 plug helps the versatility aspect. The inverter type seems like a fit, but is it developed to be rugged enough to withstand years and years of abuse?
Once that is narrowed down I would like some recommendations of welders for the heck of it. I know Miller and Lincoln are good brands but not much else. There are probably companies that are better with certain types and through certain ratings so any direction would be helpful. Please keep in mind I do live in the us, so if you don't know of anything available here thats ok.
Thank you in advance for any responses. If you need more info, just ask.
edit: I forgot to say that I already solder quite a bit with electronics and surface mount components. I thought that might be a useful background before welding. It also gives me a lot of experience with electronics so I might be able to fix the inverter types if absolutely necessary, but I would prefer it to just work.
