ProCage
Thing is you can't run a torch that is water cooler with coolent as it will burn up, I have to go weld stuff at peoples places and I take my torches and they don't have coolers so I think it depends on what you do but in a ideal world you need both, otherwise If you cooler breaks down your welder is usless. I will get a water cooler for the top end later In year because it's not the top end stuff that is the people, it's being able to run a ck9 upto 200 amps that's what I would need.
Also no water lines means super light weight on the ck17 :-)
Its (I think) tacking function where pulling the trigger runs a small marco you have setup,
sounds like more work to me, quick twist of the knob and I'm at xyz amps required to tack, simple
