I live along a 1 mile long unmade road and dont have headlight problems, though its quite bumpy!Potholes.
Had them in one of my Minis, melted the headlight switch. I did also have 4 Lucas 700 spots on a works rally lamp bar. You can never have too much light on the road.I remember them, think they were 100/80W instead of the road legal 60/55W.
Have an aftermarket hid kit from Auto bulbs direct in my Freelander 2. Standard Hb3 bulbs were crap, poor light and lasted no time. The hid kit is literally night and day different. Not technically road legal but doesn't dazzle other road users and passes mot with no issues.A good LED replacement bulb may fair better although they are not technically legal (not in the UK at any rate if fitted into a "normal" incandescent lense).
The actual bulb filament is very fragile and the road you described won't help.
Local bike garage says they can be legal, if the beam pattern falls within MOT regs.A good LED replacement bulb may fair better although they are not technically legal (not in the UK at any rate if fitted into a "normal" incandescent lense).
Well dip me in chocolate and throw me to the lesbians
Never heard that phrase before. Cheered me up no end that has![]()
Ivanhoew. He joined RetroRides in 2017 so during your time.Who is Robert? Haven’t been on retro rides for years.
I probably used that phrase on there about ten years ago…![]()
Some psa vans have a smart alternator that adjusts it's charge rate according to battery voltage. After startup or under load the alt whacks the volts up to near 15v to charge the battery ASAP then drops way down to 12v.higher voltage than normal from alternators seems common these days
maybe something to do with agm batteries or stop/start systems requirements for higher battery cappacities and faster recharge?
i have tested a Peugeot/Citroen van before and noticed 15v charge and said "that doesnt seem right" to the owner so they took it to Citroen who tested and said it was normal as it has an agm battery fitted![]()
