frank horton
V twins are great but 4"s rule.........
- Crete, Greece
anyone recomend a firm....not done too well with google.........
need something thats easy to bolt together light enough to use telescopic boom or truck mounted Hyab....
the only firm I've found will not supply unless they errect it plus personell trsnsport and expenceses at £250 per person per day.......stuff that......!!!!!!
local labour is not a problem.......
barn size ideally 15mx15mx5m high but 12m width would be OK as a minimum........
always built my own frames (RsJ) but wont have to forks lifts and other lifting gear of my own etc...
basically this is to be built in a field and errected.....if I wanted a ready built RsJ framed kit it would have to be transported, 10 hours on a ferry and prob 3hrs either side...only available in Mainland Greece......
also, I'm now almost 70 and just cant do the struggling anymore, so resigned to buy a building kit........
instead of RSJ the main frame is a pressed / rolled galv strip......prob 2@4mm thick bolted together for each corner and the apex frame........
a recomend is what I'm after.......Know of anyone to deal with direct........???????
ta........
ta........
