I need to print some 2" screw on letters. The kind you used to buy from your local hardware store. I've looked on thingiverse and cant find any. Could someone point me in the right direction. Thanks/
Very easy in fusion 360 or similar. How are you with CAD?I need to print some 2" screw on letters. The kind you used to buy from your local hardware store. I've looked on thingiverse and cant find any. Could someone point me in the right direction. Thanks/
I've looked on thingiverse and can't find any.
what on earth is this all aboutYou are using the wrong search terms. You need to look for 'ose. On the next shelf to the four candles.
They're toying with youwhat on earth is this all about
I know, I was toying with them.They're toying with you
Thanks for that. I'll give OpenSCAD a try.Maybe one of these would do the trick:
All Alphabet Letters A-Z by 6brueder
All letters: ABCDEFGHIJKLMNOPQRSTUVWXYZ@ uppercase and these chars: 0123456789?-+ââ¬$&#()ãÃÂ¥. They are based on the the Bitstream Vera Bold Font. Please check the license here http://www-old.gnome.org/fonts/#Final_Bitstream_Vera_FontsThe chars have a height of 40mm and are 10mm deep.created...www.thingiverse.com
Letter M by vuglu
If your name starts with M - your desk is the place thing thing!www.thingiverse.com
Letter Magnets by kitlaan
Print your own letter magnets for the kiddos to spell with.www.thingiverse.com
This OpenSCAD will make a letter of any height and thickness out of any font on your computer:
// In OpenSCAD, choose Help, Font List from the menu //
// to see what fonts are available to you. Substitute //
// the name of the font you require below //
font = "Wingdings";
// Type the letter you want below //
letter = "M";
// change the font size here//
size = 100;
// set letter thickness here //
thickness = 10;
// Please do not touch anything below this line //
linear_extrude(thickness){
text(letter, size, font, halign="center", valign="center");
// script ends //
