The cheap led bulbs on ebay make a huge difference to the interior lights in cars
there excellent and getting better by the year . just don't believe the crap they last 25 years. I've fitted hundreds. out of that about 25 have been returned faulty and they were branded names. I date every bulb I buy with a waterproof marker and the supplier
I've fitted LED's to a couple of cars with mixed results, I did the dash on one car and it vastly improved the warning lights plus you don't get the problem where you miss a warning because the bulb has burnt out, but on the other hand I did the front sidelights on the wife's Pug and both of them blew inside a couple of months.The cheap led bulbs on ebay make a huge difference to the interior lights in cars
u will buy cheap crapI've fitted LED's to a couple of cars with mixed results, I did the dash on one car and it vastly improved the warning lights plus you don't get the problem where you miss a warning because the bulb has burnt out, but on the other hand I did the front sidelights on the wife's Pug and both of them blew inside a couple of months.
You cheeky sod, cheap crap my **** I spent all of £3 for a pair of them deliveredu will buy cheap crap![]()
Ok so I've bought cheap once and been burned, where can I get some quality T10 wedge LEDs suitable for fitting as sidelights ?
dunno I only buy the 240v ones and there's hell to pay if wholesalers sell me a duff make and don't let on there crap and get loads backI've fitted LED's to a couple of cars with mixed results, I did the dash on one car and it vastly improved the warning lights plus you don't get the problem where you miss a warning because the bulb has burnt out, but on the other hand I did the front sidelights on the wife's Pug and both of them blew inside a couple of months.
All the LEDs I used were nominal "12 volt" versions suitable for use in a car so they should be able to cope with the normal range of voltages seen in a car.A common mistake people make with vehicles is the incorrect resistor value, they often base calculations on 12 volts and don't realise that the average car battery is around 12.6 volts, and when its charging the alternator can provide up to 14.6 volts (depending on make) into the lighting circuits.
So are all these bulbs direct replacement or does one have to reduce the supply current?
