julianf
- devon, uk
I have zero idea when it comes to these things -
I want to fit some led lights into a ceiling that, from inside to out, goes -
Plasterboard
about 50mm of cellotex
then another layer of 200mm or something like that
then membrane, battens, slate and then the outside
I would clearly need to carve out some of the cellotex. Are "fire rated" to stop fire channels between floors? Or are they to stop the light setting fire to whats around them?
I obviously dont need to worry about setting fire to the sky in the worst case scenario!
Im not bothered about U value. Im talking, probably, two lights, not 30-off!
How much clearance do led lights need above them? Do they need any clearance at all?
I have tried to look this up, but, the trouble is, if you know nothing, you dont even know what terms like "fire rated" even mean!
Thank you
Plasterboard
Thank you
