brightspark
- yarm stockton on tees
patch it up temp and leave till better weather . not even worth thinking about doing it now
Lino is also good for inside your bootsA pond liner can be used to cover a flat roof...![]()
oil clothLino is also good for inside your boots![]()
£1500 plus supply my own ply wood.dont think so budYou have PM
So any water reaching the "bottom edge" won't actually drip into the gutter, it will go round and back under the sheet.
It will then continue "down" and drip off at the lowest point, in line with the window, probably? That's where its pooling deepest.
Nothing much will help with the drip edge issue unless you either straighten the beams or increase the pitch.
I was trying to give you a guide on your "local" estimates you fool£1500 plus supply my own ply wood.dont think so bud
I was trying to give you a guide on your "local" estimates you fool...been trading since 1980 and i certainly don't need to buy your work to feed here. Next time you receive a PM offering help out of somebody's own time at least have the decency to say thank you.
