I am making a kitcar using a petrol tank from a Triumph Spitfire.
You can see from the photo that I have drilled a hole too close to the tank seam and have now found that it is leaking from this point.
The petrol tank has not had any fuel in it for the last 20 years and I filled it with water today to test for leaks.
My question is whether I will be able to cure the leak by welding-up the hole? If so, is there any special technique that I will need to use?
Thanks
Chris
Thanks
Chris
