T0rnado69
DIY nut !!
- Essex
now i know most of you have big lathes, unfortunately i just dont have the room for a lathe like that.
would love one, remember using one in school when i did metalwork..
biggest one i could really get was a clarke 430L and make a drip tray for it so i could mount it on the end of a long bench.
as apposed to having the metal stand for it.
a few idea's to upgrade are..
1. tool post
2. collect chuck
3. ball screws X and Y
4. or fit a DRO instead of ball screws.
so tool post..... something like this
only issue is my slide is about 65mm, so that one will overhang 7mm from and back, and left side..
if i go to the smaller toolpost, then it wont hold the tools i have (12mm & 16mm) and probably not be high enough to hold tool tip on centre height either.
(my current issue with current tool post) ive had to put 6mm spacers under the top slide to get a bit more height to get tool tip on centre height.
and is it possible to get some holders machined out to take the 16mm tools...?
collect chuck.... the plate my chucks bolt to is 130mm diameter,100mm register and the 3 holes (9mm) PCD is 99.5mm
found 125mm or150mm, 150mm has a bigger register, so thats no good.
so 125mm seems to be the size, one i found here
only issue is PCD is bigger. so is it best to make an adaptor plate to join the two together or.... drill 3 new holes in the collect chuck with 99.5mm PCD.
ballscrews or DRO
so for a while ive been toying with the idea to get some ballscrews to get rid of the backlash, more so in the cross slide really.....
but after watching some videos of DRO's, fitting a DRO might be a much better idea.
i mean fitting ballscrews should get rid of the backlash on the axis, but fitting a DRO, yes your still have the backlash on the current screws, but unless the slide moves it doesn't register on the readout. and a dro will be much helpful when machining stuff to size.
cheers all for thoughts and suggestions and ideas.
1. tool post
2. collect chuck
ballscrews or DRO
