So more like what you would use to cut plasticYes I'll take a pic of it tomorrow. I bought the discs for sharpening carbide scrapers but they also do a great job on lathe tools.
Grind the top of the tool at a sharp angle down away from the edge, to form a more knife-blade cutting edge. It will slice through softer materials instead of brute forcing the material away. The results will surprise you when you first do it.
But terminology is awkward as if I was explaining it in English I would say a high rake is less rake but it's measured from the 90degrees so a 2 degree rake is lower that a 15 degree rake.
I am guessing any one starting out would end up confused....like I used to.
