Yet you can have a 10.5kw shower on a domestic supply!
3hp is about as much as you want to be running from a 13A plug socket, but that's commonsense rather than a rule or regulation.I am sure that I read somewhere online that there was some kind of regulation making 3hp the biggest vfd you're supposed to sell for use on a domestic supply but I am damned if I can find it in a search now.
what is the biggest vdf u can get at a reasonable price and why limited to 13 amp when u have minimum of 60 amp supply to your house
10hp/7.5kw for 200quid, hungyang?
Noop. They need a brake resistance beefing up if you intend using the eStop function
Tos ???? who is that ???
I stand corrected, although I'd be wiry of buying one as it states 220v in the description but in the spec table is says 380v.
Every Huanyang manual I've read states that above 4kw 3ph input is required.
