3mm 8x4 is £100 if you buy a ton2mm. That's literally tin. It's just coming off a coil.
Who wants a ton though.3mm 8x4 is £100 if you buy a ton
Having fusion issues. I had hoped someone would have some plans for the certi-flat style I could buy off them.Why don't you just draw what you want?
It would be a tonne of work, to draw a tab and slot table from scratch. Let alone working out the right amount of clearance to leave.Send me a rough sketch and I'll draw something up for you
You’re welcome to send him what I sent you Brad. That will cut down on his work.
That does seem good value. I'd just like something a tad thicker. 8-10mm I guess I could live with.Though this seems bloody good value for money.
Welding Bench/Fixture Table 2000x1000mm Laser Cut option 2 | eBay
Find many great new & used options and get the best deals for Welding Bench/Fixture Table 2000x1000mm Laser Cut option 2 at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
I'd just draw the base then use copy array then construction lines and parallel offsets to get the tabs, again after that it's all copy and paste to use the same cut component to make majority of the parts
If you are going to the trouble of drawing it up, why not do it parametrically, so it is scalable to any size? It would not need a heap of variables: length, width, thickness, hole diameter and grid. You can relate tab size to thickness and a little bit of maths will give you number of tabs on each edge.
I am just starting to look at OpenSCAD, and it looks ideal for this. What I do not know right now is if you can send parameters between files, so it will spit out a top, long side and short side with one set of input numbers.
Looking at the photo above, are the stiffeners under it the same as the sides they are parallel to? If not, could they be made so?
I believe it is possible to post dxf files as attachments to posts here, so if anyone wants to share, please post. At worst, you will have to save as an ASCII dxf and change the extension to .txt .
You got lucky! Steel benches like that aren’t held in stock at that price!What is wrong with buying a steel table and drilling loads of holes in it with a mag drill?
I only paid £250 for an 8x4 bench with a 22mm top.
Did you see my neighbours tables?That does seem good value. I'd just like something a tad thicker. 8-10mm I guess I could live with.
David Demoise on Instagram has offered to send me a 2x1m file he has in metric.
I've been thinking and what Clive said probably is best. Two small tables, that can be bolted together. If I could get some boxes made say 1000mm long. They could bolt the two tables together, making up to a 5m table from two 2x1 tables or a table 3M x 2m.
No need, it will autoscale being a DXF you'd only make the linear array and hole size parametric and you sensibly make them some ratio of the overall size.
