zx9
- South East London
I wonder how many customers really wanted that self-locking feature.
You can enable / disable auto locking (if available) very easily in VCDS for VW Audi etc.
And they use the same ECU to do multiple tasks, instead of discrete systems. This is the biggest problem in my view as any faultin the ECU can make the car do crazy things. A friend of mine was driving a Fendt tractor along the road, flicked a switch to set the transmission to auto speed control (Fendt have a variety of operating modes for the transmission depending what your doing) and the next thing he knew he was smashing his head on the dash because it had dropped the front end loader, which had spikes on it, straight into the tarmac. Very nasty, and begs the question, why on earth would you need to hook a hydraulically controlled loader to the ECU in the first place?Hi, There's a thread on another forum I use, of a breakdown recovery guy and he relates some of the breakdowns he has. Electric handbrakes usually fail in the on position and 90 per cent of the time he ends up attacking it with a hammer and chisel and recover it to the main stealer or customers garage of choice, or as said a suspended rear tow.
Some of the problem is manufacturers put these computers in the car for the engine management but they have more capacity than is used, so they keep adding other gimmicks to use this spare capacity usually things that are not essential but look bright and shiny for the gullible.
Colin
Agree entirely with your sentiments. But I don't think the Herald handbook had any advice on how to weld in new chassis outriggers, which might have come in handy......this is a page from the drivers handbook from 1968 of a Triumph Herald.....
You guys need to drag yourselves into the modern age. I don't hear anyone hankering for points ignition or wooden spoked wheels![]()
Most cars don't have one...they have several
Mine has
ECM - Engine control module, also holds key details
CIM - Column interface module - holds second set of key details (replace ECM or CIM the data will sync from the other...replace both at the same time....new keys time) as well as stuff to do with steering column
EHPS - Electro Hydraulic Power Steering
UEC - Underhood Electrical Centre - under bonnet fusebox with a bit of intelligence added to look for excessive voltage drop etc
REC - Rear Electrical Centre - Fusebox in back of car, rear lighting, towbar etc
BCM - Body Control Module - interior lights, ventilation etc etc etc
SRS - airbags etc..
EHU - Entertainment head unit - tuner and "brains" of the stereo
ICM - Infotainment control module - stereo display and controls
ABS
Traction Control
and there is probably more I'm forgetting....
In the last 20 years I have had one car 'accident'.
Someone reversed into my car while I was stationary - I can't see any electronic 'aids' preventing that...
I get more than 20mpg.
I have never had a car with ABS, TC, ESC or any other 'safety' acronym and I'm still alive.
Am I magick?
What about if their car had reversing alarms/sensors?Someone reversed into my car while I was stationary - I can't see any electronic 'aids' preventing that...
Yep I have done rear pads and discs on an insignia too for a girl in the marina , no special gear was needed - just brute force and ignorance as normalI've done rear pads on insignia no electronic gear needed at all. It's straight forward and simply wind pistons back in as normal
A Morris marina nick? No electronic brakes on them badgers palYep I have done rear pads and discs on an insignia too for a girl in the marina , no special gear was needed - just brute force and ignorance as normal
What badger? It was only the car I was servicingA Morris marina nick? No electronic brakes on them badgers pal![]()
Sorry mate thought you were talking about your neighbour for a moment.....What badger? It was only the car I was servicing![]()
I am ignorant about the technology, so please educate me. If an electric handbrake goes wrong, does it lock “on” leaving the car immobile, or does it remain “off” so that you cannot safely park on a slope or change a wheel?
Is there any sort of manual over-ride control?
In the event of an electrical failure, can the car be towed home?
