doubleboost
- Newcastle upon Tyne England
R8 is not compatible with int30proper feeds and the Spanish make some proper machines. if its 30 int r8 tooling will still fit
Going back to cylinder head skimming, isn't a 12" fly cutter massive? The last few cylinder heads I've had done have been done with a grinding stone, 'like' a bench grinder. I initially thought that tilting head might go to 90 degrees, but looking again I don't think it will. Couldn't you do numerous passes with a smaller fly cutter? Or is that just silly?
I meant the other way around, you can use 30int in r8 . Seen it with my own eyes as explained in a later post. Check machinery handbook for dims and you will see same taper.R8 is not compatible with int30
Morse are locking taper ints and R8 are not , though in practice they can and doSo similar to a MT, just a different format, or is it tapped at the top for a locking bolt?
I think the angles are slightly different from memory. Not a lot in it but....I meant the other way around, you can use 30int in r8 . Seen it with my own eyes as explained in a later post. Check machinery handbook for dims and you will see same taper.
If I hadn’t seen it myself I wouldn’t believe it either
I used to have a plough grinder if used for heads with proud hot spots.You can quite happily fly cut aluminium heads with a flycutter. I have a 2inch thick, 9 inch diameter single point flycutter on an int 40. The one thing I refuse to do are diesel heads with steel inserts.
The mill is an old FritzWerner, I think it was used to make bombers...
