brightspark
- yarm stockton on tees
anyone know what type of grease is needed for the 900 kango hammer. i was told mobilplex 47 but dont know if its rite stuff. thanks
no they were taken over by milwaukee and no longer keep spares. ive used other grease and it doesnt work properly . either works at 1st then breaks down with heat and stops knockingCan't imagine its that critical? Do Kango have a technical help line lot
theres a piston inside a sliding sleeve which fits in to the barrel which works pneumaticaly to strike a pin in another sleeve to hit the chissel bit the correct stuff is neededWhat's the grease for, to grease the bit, as with an SDS or to grease something internal?
I'd imagine similar stuff used on similar breakers would do.
I'd ask the local tool hire blokes. Mine have been pretty good giving advice like that and finding bits and pieces for older gear.
thanks for the info il ring them
yes and the sleeve and crankI gather its to grease the piston, rather than the bit...
Lacking any further info I would try LM, since it will get runny very quick.
ive sourced some kango grease packs but it doesnt tell u what it is on the pack £14 quid enough to do 2 breakers
