Hi Guys
I'm completely new to welding and have just picked up a used mig welder to help me with Triumph GT6 restoration project
The welder needs a few things servicing on it, so if anyone can help me out that's be appreciated
I've been speaking to a few Triumph owners and they say 0.6mm is good for both the bodywork and the chassis
The welder came set up as 0.8mm
Do I need to change the 'roller wheel' in the wire feed (as it says 0.8) or can that still be used with 0.6mm wire?
Things I know I need are;
Earth Clamp
Shroud/Nozzle
0.6mm Tips
Regulator
Gas
If anyone can point me in the right direction that'd be great
The welder is a Cebora Craft Mig
Is there anything else I should check on this unit?
I understand they're not the greatest Cebora's out there, but I'm sure it's capablities are way beyond those of a first time welder such as myself
Thanks everyone
Ant
Earth Clamp
Shroud/Nozzle
0.6mm Tips
Regulator
Gas
Thanks everyone
Ant
as the Type 25 are commonly used in fab shops & the same thread size as the Type 15. Use the correct ones (type 15) as the 25's are wider bodied (to cope with higher amps) but will clog up with spatter quickley within a Type 15 gas shroud
