Easyrider
Hi guys
Played around with some stainless today ..
The Spec
1mm SS
Tec Arc 206i
30 amps little pre/post gas
Gas 10LPM
Tip is pointed and aprox 5mm proud of the shroud. (2.4mm)
good penetration but as i'm carressing the puddle I get a flash of light which is not being filtered by my mask ( auto type)
I get temporarily blinded and have to focus again where the pool is..
Have tried cleaning the tip, plate and even clipping the end of the SS rod too ... .
Weld speed is obviously slow and I even dropped to 25amps with no filler just to see how that looked.
The Mask is set to the following
LHS scale of 9-13 its set on 11
RHS scale L-H set on L
Really not sure what should be where so some advise on the mask would be helpful too (paid about £40 quid for the mask if that helps clarifying whether it should be living on my head or in the Bin!!! (ONLY GOT 1 SET OF PEEPERS)
Finally ... dipping the rod seemed to contaminate the pool even clipped the end off but still put in more ****e than seemed acceptable
The Spec
1mm SS
Tec Arc 206i
Gas 10LPM
