if its full working order should be good. 3.2mm is probably the biggest you can burn with it but might have to work hard for that. Will also do scratch start TIG.
At 150amps you can push a 4mm 6013, range for those is around 140-180amps. But you can do 7024 3.2mm which are about 140amps. So you basically have a machine capable of runing almost any 3.2mm rods
Yes, good kit It'll run 4.0mm rods.
You need to be careful with second hand Inverters though...don't go giving a lot of money because they can be expensive to repair if something should go wrong.
weldequip
Not sure about the booster function, but i noticed the back plate says 150amps, and the side says 150amps, but the dial shows 160amps, just noticed the lower part of the picture WIG 5a to 160a. WIG being TIG, (either that or you can put it on your head and turn it up to 160 amps)
If it all works ok for 60 euros which is about £60, i dont think you got a bad deal, get a tig torch and Argon gas and you can scratch start Tig as well
Bargain. REHM are a respected German manufacturer, certainly not Chinese rubbish...although there is a certain outfit trying to kid people into thinking their kit is German...with a very similar name
weldequip
He already did mate...catch up!
I was searching the famous auction site last night for 'the other' REHM & no sign of em, looks like they could of gone!
weldequip
weldequip
Everyone has the right to make a living, everyone has got the right to sell stuff, competition is a great thing, but I detest companies, who try and trade on other peoples good name and reputation and try to mislead people as to where the stuff really comes from
