Cut the shape of the coving out of the wardrobe!
yup, plus one for me..... wardrobes come and go, walls tend to stay put.... ahhahahhaha
Jack up the entire floor and add a course or two of bricks. It's what they would have done in the good old days.
it worked verry well and fast with hardly any damageJust picked a dewalt one up from screwfix. I was looking for a reason to buy one and I think you're right, that this looks like the right tool.Beg, steal, borrow or rent [or even buy] one of these CLICKY.
I seldom use mine, but it's been a boon on occasion![]()
Or cut the shape of the wardrobe out of the coving.Cut the shape of the coving out of the wardrobe!
Yeah - the good news (Multitool...and to keep this thread on topic...make your own extended multi-tool blade by welding 2 together so will reach all the way behind the coving.
In a pinch I made on out of an only hacksaw blade welded to the end of a trashed blade (it was sunday evening and the job needed to be done!)
) seems to be that the cowboy builders only attached the wall board and ceiling to within 2" of the join so that's all that needs to be cut.Usually only 30mm of surface on wall and ceiling that sits flush. Plenty of depth on a normal bladeYeah - the good news () seems to be that the cowboy builders only attached the wall board and ceiling to within 2" of the join so that's all that needs to be cut.
He waswasnt Black beard the Pirate called Edward Teach?
Most builders don't,Do they bother making a good job of the plaster if they know coving is going up, or is it like skirting, where the plaster is often not good behind?
Check for electrics...people do some odd things!
yep like putting cables behind them and guess what . thats aceptible because the cables are routed in the safe zones
Yup...and also when you reach down to the floor you drag all of the crud up the wall and ruin all your work too!They don't plaster behind skirting board for a reason
They don't plaster behind skirting board for a reason. It transmits any damp up the wall and sends the skirting black and mouldy.
