I will try to use the lingo. For the life of me I cannot get a root pass fillet weld on the inside corner length of a T-joint. Just working with 1/8" (3mm) cold-rolled low carbon steel. Running around 120Amps, 3/32 2% Lanth, 1/16 ER70S-2, 18cfh, #8 cup. I tried dabbing then lay-wire. I mostly get globs on both faces either side of the joint. I did get a couple of centimeters of weld actually in the corner joint (at the point of intersection) but that apparently was luck.
Is there a technique I should know about?
My profound appreciation in advance.
). I didn't know why though. Arc length was long (as played back in my mind) and the effect as you described is reflected in my results. I was afraid to increase the amps because I was already melting material away. Looking forward to executing your advice. My gratitude! I tried some butt joints, they did work out better, enough so to see the progression path you recommend.
