A alpinejim New Member Messages 1 Jul 3, 2009 #1 Hi I am planning on building a bbq with a hefty 8mm stainless steel rod griddle. I already have an SIP Migmate Turbo 130. Would this be sufficient to weld this rod and which size wire woud you recommend i use? Thanks for any help you can give.
Wozzaaah The wizard of woz Staff member Messages 17,495 Jul 3, 2009 #2 It'll be fine for that, it's not structural so just needs to be held together. 0.8mm wire and clean the millscale off the weld areas to ensure you get maximum fusion
pedrobedro Man at Matalan Messages 13,077 Location CX near Chesterfield Jul 3, 2009 #3 Grind a flat on the ends of the rod where it rests on the frame and you'll have a thin edge to weld to.
Welderpaul Member Staff member Messages 14,646 Location UK Jul 3, 2009 #4 Wozzaaah said: clean the millscale off Click to expand... Wot, millscale on stainless?
Wozzaaah The wizard of woz Staff member Messages 17,495 Jul 3, 2009 #5 Hehe, didn't spot the stainless bit! I'm sure he edited after I posted
Robotstar5 Casanunda Staff member Messages 23,024 Location Birmingham Jul 3, 2009 #6 Wozzaaah said: Hehe, didn't spot the stainless bit! I'm sure he edited after I posted Click to expand... But being a mod, can't you edit it back to suit your answer?
