hi folks, i have just spent a small fortune on all the gear to run a air fed mask. can you please confirm its safe to spray now. the compressor is a brand new sip 20 cfm,i have a brand new 15m hose from compressor to my 3 stage filter, then a 10metre breathable airhose from 3 stage filter to the carbon filter on the belt, the mask is a Sperian Air Fed Mask Respirator Airvisor 2. what psi should i run the mask at, the alarm goes off at around 6 bar so i put it to 8 and its fine, is that too much pressure? i know it sounds daft having a normal air hose going to a breathable but i was told it didnt matter as long as its clean and i already had it split brand new unopened.
let me know if im ok to go spray 2k.
james
james
