I have a kuhtreiber kitten 170 https://en.kuhtreiber.com/products/invertory-mma/kitin-170/ Bloody good inverter. It doesnt do a lot of work, its stored in shed on a shelf.
Was using it wet day last Feb and when I plugged in and turned on, 2 seconds later there was a loud bang and tripped the trip switch. no smoke. I thought it was dampness somewhere, Turned back up the trip switch and all was good, burned my 5 6013 rods at 90amps.
Welder was idle for a month sitting on the shelf and when I used it middle of March there was a repeat of the above incident, a loud bang and tripped the fuse. no smoke Turned up the trip switch and did the bit I had to do no issues, and left the welder on the shelf.
Last Saturday I had another bit to do and when I pressed the switch to turn it on, the lights on the welder flashed on and then cut out. After the 5th attempt the welder started up. I thought I had a faulty switch.
First spark of the rod the welder cut out and now it just flashes the light when I try to turn it on and thats all it does. Its not tripping the fuse.
Any ideas
Any ideas
