GrahamGKD
Hi Folks,
Help needed from the electrical experts on here please – again!!
Our house RCD has started tripping very occasionally (like 5 weeks ago and then again the other evening). Both times it has happened the RCD will not reset initially but the fault goes away within a minute or so so there is no time to try and work out where in the the fault is coming from. Our consumer unit is way before 17th Edition so the whole shooting match goes off (including the freezer).
My workshop is now on a completely separate circuit from the meter so it is nothing to do with that (thanks Brightspark – that was a great solution for the workshop problems I was having a while ago). The only external wiring we have is a set of outside lights but they are on a double pole switch and that circuit was switched off at the time. It was raining the second time this happened but we think it was dry the first time. There is some wiring down the cavity and under the floor so I guess there is potential for something to be getting damp.
So – what can I do – thoughts I’ve had so far include:
Wait for the problem to become more frequent – the freezer is the most critical thing and I could buy a cheap one and stick it in my workshop temporarily.
Change the RCD – I had some problems with it tripping with my compressor starting and plasma running before I split the workshop supply off – could the RCD be flakey (it’s a GE, maybe 18 years old).
Fit a new 17th Edition CU - at least then the source of the problem would be divided down the middle and the RCD would be replaced with two new ones. Only problem might be that some of the tails coming into the CU may be on the short side.
Any suggestions would be much appreciated – Thanks.
) a length of twin and earth cable that had been crushed against a joist edge by a careless boot and was leaking between conductors when disturbed.
- I only paid £225 for the bl88dy washer!
