BrokenBiker
- Newport, South Wales
my need to build a shed, has now turned to a need to get a shed asap. in amongst work and kids will likely be in next 3 weeks or so. my original idea of building one involved a steel frame with OSB and insulation then some decorative cladding on the outside, however thats going to take far too long now so its looking like a metal 12x10 unless i can find a decently priced wooden one.
need to try and eradicate any condensation/damp from the start though as its going to house the welders and bench, my mini lathe, pillar drill, bench grinder and possibly a 3d printer, and id like all of them to stay as dry as possible for obvious reasons.
the base/floor is pretty much sorted, ive got a 13x11 floor plan of mesh grids coming, with a DPM and some OSB that i will treat before laying down. ive checked with the manufacturer and the grids are perfectly fine to be left empty to allow air flow under the OSB floor which should also help reduce any issues there.
any suggestions on the condensation issue that plagues virtually every metal shed? i know air flow is a big thing but there isnt a massive amount i can do about that really. i will likely have some form of extraction in there, but it wont be anything impressive and mostly just to sit about welding bench and run straight out the wall. i did initially think of the self adhesive rubber type insulation used in camper vans, and possibly some thin ply on top but not sure how effective that would be
