I guess that might be my problemits just a join strip with a u channel but you do need to use enders near a wall as walls do go out and therefore you can adjust the cut and hide it under the trim
you may have to pack it but at least you can get the whole roof insulated at low cost
the cladding comes in 5m lengths work out the best way for your cuts to use the least amount of material lost
corners are the same just use a joint strip and
dont forget plastic cladding boards can be used as well both the cladding will be affect by heat and so will the insulation mdf insulation board it always does
Where was the link to 5 metre lengths of 20mm vladfing . All I can find is 2400 x1200.its just a join strip with a u channel but you do need to use enders near a wall as walls do go out and therefore you can adjust the cut and hide it under the trim
I like this one....ive found a pic for you and also with my search terms so you can see how it looks on a ceiling with cladding
upvc cladding conservatory ceiling - Google Search
www.google.com
gardiniawindows.co.uk
Yes that's correct.is that 1st pic the lowest point
whilst the 2nd pic is the highest point
is there any windows direct to the roof within that part ?
your going to play with thickness vs thinness vs cost
Those fridge panels are 25 quid per metre. So not cheap. But I suppose its better than Decimating half the amazon rain forest doing it Bob's way..lolyou can buy fridge panels
Flat Both Sides White Insulated Panels:1100mm Wide,2200 Mm Long,80mm Thick, | eBay
Find many great new & used options and get the best deals for Flat Both Sides White Insulated Panels:1100mm Wide,2200 Mm Long,80mm Thick, at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
or 8obs way
Mancave extension
I thought they were reasonable at £250 so £150 is a result. With that Farm2000 and a few of these you could probably get a workshop to the point it's too warm to work. I was going to fit a thermostatic switch to the fan motors, I suppose I could just fit a thermostatic rad valve to the flow...www.mig-welding.co.uk
I think cost wise it's going to have to be Kingspan or similar.its all down to cost and what your willing to pay to get done
as goes for the window lights id make a frame up to the size i was wanting and just do what i did
but i didnt seal the panels as they need to come back down to clean them every now and again
thats why ive shown you what i did 8ob roughly followed the same reference it does work and it throws alot of light around
once you start to insulate you will block alot of light but you can gain alot back add some led strip lights and it will be bright in there more than you think
its either metal or its wood or plastic but beaware heat will affect plastic
You got that spot on. Lolyour going to play with thickness vs thinness vs cost
Is there a manufactures data sheet that gives the R value of the different thicknesses?Certainly playing with cost v thickness.
I was set on getting 75mm at £26.50 plus vat.
Then someone threw a curve ball and said they have 12 sheets of 100mm 8 x 4.
I asked the price and they want 40 quid a sheet. (With scuffs and dinks in them although new)
So I checked this morning and the place that has the 75mm also has 100mm in stock that works out at 42 quid INC vat.
So unless the guy reduces his price I am not going to buy his for 40 when I can get brand new (no drinks etc).
BUT and this is my dilemma. How much better are the 100mm.
I know they will be stronger but I don't think 75mm will sag or snap over a 1.85metre span. Are they however much warmer.
How do I gauge the extra thermal values against cost. 420 quid v 318 if my maths is correct.
Assuming the same material for each it’s directly proportional to the thickness. 100mm is going to be 33% better than 75mm. Which is almost exactly reflected in the price you quoted.How do I gauge the extra thermal values against cost. 420 quid v 318 if my maths is correct.
