Blobber
- lincolnshire
On that I would just run 10/40 semi synthetic, run it for a bit on that and if its still using oil my 1st port of call would be valve stem seals at that mileage, as others have said get someone to follow you and see when/if it smokes, up hill under load is rings/bores and down hill coasting will be valve stem seals is a simple test I believe
