Guineafowl
- Nairn
Yes, most likely the inverter voltage sag/overload shutdown.Or software
(it does have a 2700W power lifting mode, but that changes the output from pure sine wave to a modified wave for resistive loads), and is typically supplying 2-400W through events
Bluetti don't mention surge though, they specifically say power lifting.That is most certainly not my understanding of “surge”.
Surge, to me, means a relatively short occurrence where the current (in this case) temporarily exceeds the normal operational maximum value.
I'm not sure it's entirely square wave, but as the manual mentions, there are other limitations to using that mode.why is everyone ignoring this? laser printer will be fine with square wave
The power bank shuts down the 240V output due to overload.What's actually tripping?
Is it a MCB or RCBO?
Most likely ‘modified sine’, for which read: ‘not sine at all’. Sort of a square wave with gaps. Very harmonic-y.I'm not sure it's entirely square wave, but as the manual mentions, there are other limitations to using that mode.
Somehow I assumed it was tripping somethingThe power bank shuts down the 240V output due to overload.
Probably, but that choppy waveform might couple spikes through to the DC bus, and befuddle the processing. Also hard on the PSU caps and silicon bits, so might shorten its life. Hard to predict.but... it'll be fine once it's rectified to DC in the printers psu (I think?)
