Does anybody know of any mains voltage inrush current limiters, that would limit current to around 2-3 amps?
The full situation.
I work at various events, and can run of a portable power bank for most of the day, however my laser printer (bought to replace the inkjet, as due to the very limited use, the inkjet cost me far more in cartridges, plus there was the continual faff of when it didn't print well when needed!) trips the overcurrent protection on the power bank.
The power bank is a Bluettie AC180, which is capable of 1800W AC (it does have a 2700W power lifting mode, but that changes the output from pure sine wave to a modified wave for resistive loads), and is typically supplying 2-400W through events. The issue is when I go to print, when the laser printer kicks in, it often trips the power bank output.
Officially the printer uses about 400W while actively printing, but having done a bit research about similarly sized laser printers, some manufacturers list a peak current of around 1000W, so there is obviously a surge as the printer heater kicks in.
What I'd like to try, is an inrush current limiter that would limit the current to 2-3A, to see if that's enough for the printer to kick in without causing any problems.
MeanWell do an inrush current limiter (ICL-16), which would seem like the ideal solution, but only in 16A form.
The other options are I buy a bigger power bank (££££), build a system into my van (£££, but removes portability), or go back to an inkjet (££, but lose the benefits of the laser printer).
The full situation.
