angellonewolf
- bristol england
Ok side garage what was changed to a room years ago there was found to be an electrical fault and the ceiling has been taken down I'm going to change the lighting as the old stuff in there is not bright so thinking of may be 8 spot recessed lights
But I'm seeing it as may be a good chance to add a 2nd fuse box just to supply a car charging point and/or supply to my garage at the end of the garden not looking for large amounts of power down there as its more for parking a car and storage so may be 1 socket and a spur for a couple of lights
The route to the back of the room would be quite short 12 meters max cable would be routed through the ceiling droped to a 2 way fuse box just cheaking what amp fuse board i could run i have 1 spare way in the main fuse box that I could put a 45 or 63 amp mcb I can't get photos at the mo but will do in a day or 2 to help out
This is just an idea while I have the ceiling down so just a thought on if its ever going to be done nows the time for it
Im thinking a 10mm cable as that short of run should easy do a 45 amp main should do but can I get away with a 63 amp
