Do not use enammeled cast iron on an induction hob. First time I tried some of the glaze transferred to the hob and wont come off, only a small bit but it was a new hobAny cast iron.
Not if you cook steaks. The glass on mine Is very hot after 10-20 mins of frying, well above 100c.Another plus;
if you have children around, the heat is transferred to pan & contents, surface of the glass only gets warm, via heat transfer back from the pan - not enough to cause serious harm when touched like ceramic hobs & other types
I like mine medium. I generally use 12 out of 14 for power and cook each side until it no longer sticks. If it were gas hob I would have it on max and might be quicker.If you cook your steaks for 10-20mins then you deserve to burn yourself on the hot glass.
3mins max for a decent bit of steak...
You can get silicon mats, these protect the glass and stop the pans from sliding, plenty on ebay.The only problem I've found is that the pans skid all over the place, I always need to hold the pan if I am stirring the contents.
Never knew that. I’ll look now.You can get silicon mats, these protect the glass and stop the pans from sliding, plenty on ebay.
Just done a stir fry, first one since the new kitchen, need to get a proper wok. Must be steel without a silly non stick plastic, which everything seems to have now. Any recommendations?
Well I may have to put my induction coil heater in the kitchen and make up a conical coil for holding a proper wok. No chance of a mains gas burner. I worked in a Thai kitchen for a while, we didnt use anything fancy or expensive, just large steel wok seasoned with oil on a massive gas burners. Im not interested in overpriced french brands. Paying for a name and a silly coating.
The problem with induction and woks, little heat will transfer up the sides compared to a gas. It could do with a thicker base and a sheet of copper formed/spun to the same shape and melted on outside to spread the heat. I might get a spare and play with tig brazing
Ive gone with this one as it has delivery tomorrow, if it works Ill get a 14" one.
www.amazon.co.uk/gp/aw/d/B000P5Q42I
Doesnt the food fall out?My other half still uses it regularly but I much prefer the bottomless ones.
Mine turns on but flashes until you give it a pan it likes.All the hobs I have ever seen need a pan that's magnetic enough for them to even turn on.
Where do you get the raw prawn crackers from?The one in the link looks a lot like one I have got that's lasted me probably 15 years or so now.
I didn't recommend it as i don't remember it having any name on it when I got it!
The coil bowl up and around the sides is how the wok induction hobs work.
The shape of a wok is not an ideal shape for gas as it pushes most of the heat up and away.
The gas wok burner I have is something like 5.5kw, my missus won't use it as it sends so much heat up past the wok it burns her hands. A commercial gas burner is big diameter and has lots of flame running at a low velocity. My kitchen version chucks it out like a blowtorch and most of it just shoots up the side of the wok and into the extractor without actually doing anything.
The induction chucks all that heat directly into the pan and it's hot in a fraction of the time.
I have not tried to measure them but I bet it's 5X faster if not more.
Maybe not even necessary to have a wok that gets scorching hot in seconds as traditionally the idea of them was to cook on frugal amounts of fuel but I do like the ability to cook some noodles then chuck a litre of oil in and heat it enough to fry the prawn crackers before the noodles have time to get cold.
I know what you say about paying for a fancy brand name and there is nothing whatsoever wrong with a cheap carbon steel wok.
Stainless has the convenience factor, easy to clean and it won't have gone rusty the next time you come to use it so it's wife friendly.
If you want the (small) advantages of stainless on induction you do have to pay a bit more if you want good heat conduction through the thing and you want it thin/light at the same time.
I would almost be prepared to argue the value-for-money of the le cruset though..
It's 5kg of un-warpable cast iron,
It will last a life time
The way the thing heats so evenly is superb.
It's almost an art piece of design and I would happily have it on the window sill rather than the hideous cake stand she keeps there..
But truthfully, no. The food would turn out a lot better if I had spent the equivalent on cooking lessons.
