brightspark
- yarm stockton on tees
u only need a 2core for the neon as long as its in a plastic enclosure and if the wire feeding it is exposed its double insulated theres no point in earthing it . look at a table lamp that has a plastic lampholder and frame 2 core cable no earth needed . metal lampholder 2 core with earth neededNot quite with you there,sorry. The neon is in a plastic casing which used to be clicked into the metal chassis of a hob. It has two leads from its back end which are long enough to do what I'm proposing. Do you mean I should cut these off to just leave enough to connect to the live and neutral of a 3 core?
The earth can connect to the timer switch earth terminal easily enough but where would the other end go? Should I find a metal-bodied neon or another sort of light?
