angellonewolf
- bristol england
I've looked over this 3 or 4 times but can't find thr info plate any where any of you clever people in the know ?
K770 I've bought one myself few weeks ago I'm waiting for it to arrive home serial number should be next the handlebar on the belt side .View attachment 440206View attachment 440207
Ok no there's no stickers on it its very well battered looks like been chucked around the back of a van for the last few yearsK770 I've bought one myself few weeks ago I'm waiting for it to arrive home serial number should be next the handlebar on the belt side .
It's a 74cc 350 and 300mm cut off saw .
Usually they fail do to ring wear and or piston scoring do to the dust coming inside the engine cause to a neglected air filter (it actually has 2 of them)
Top end is cheap ,but you usually need to replace the crank bearings and seals because they fail pretty easily from what I've found online.
It also have a particular intake manifold which doesn't help much , in fact it's another typical part which fails
No its not hot a mate does clearances and auction houses buys he get some random lotsWould that have the serial number ?
Was it removed because it was hot ?
mine looks very simular to yours but mines a metal disk cover and yours is blue round the the top (where the air filter housing is) mine is orange but that could be down to the age of the mechineThe plate is normally where the first pic is. Then the second one is where it will say the model. I bought a few of these a while ago from auction and kept the best of them, this was annoyingly the only one the plate fell off. View attachment 440276View attachment 440275View attachment 440277
Mine has a metal disk guard, unless you mean something else. I’m sure the other ones I had were just slightly newer and had the orange trim.mine looks very simular to yours but mines a metal disk cover and yours is blue round the the top (where the air filter housing is) mine is orange but that could be down to the age of the mechine
Happened something similar to me.only 1 problem sons been round for tea and spotted the saw and there was hints that his needs are more suited to the saw than mine but as hes a brick layer hed be using it a few times a month where id be a few times a year depending on jobs at work but its mine for the moment
