richie00boy
Cellulose dries too quickly to brush on. You might have success with 2k direct gloss.
Johnstones Aqua Gloss
http://samedeal.co.uk/2-5-lt-johnstones-aqua-gloss-brilliant-white-163-16-90.html
2.5 litres £16.90
Cheapest place is samedeal.co.uk (they have an account with Johnnos and they will have the local centre deliver any order to your door for £7.99 or you can email / call them, ask samedeal to mark it for collection and they will refund the 7.99 delivery charge
Its a hybrid gloss, so goes on something similar to oil based, less odour and dries quickly...once cured its as hard as oil based and doesn't yellow. Also can wash out brushes with water / soap and water.
works best when used with the aqua undercoat (samedeal also sell it) (as they are part of a "system" I'm told by those in the trade) I find the gloss level fine after one coat, but seemingly a deeper gloss with 2 coats of gloss
Best used with a decent synthetic brush
From Johnstones dec centre directly its about twice the price...samedeal have a trade account with jonnos so they get the usual unmentioned massive discounts, so you order from samedeal, they then place an order with the nearest branch to be sent to you / collected by you. Tis a bit confusing...
Snooper - its what they call a hybrid, not water based per se, sort of best of both worlds...it dries seriously hard...I've tried fingernails after decent cure time and it doesn't scratch off...unlike asdas own brand water based...
that goes yellow in no time im affraid to say ...brushes on nice mindBought a can of brilliant white from Johnsons which appears to be non water base.
rocketman: cheers
Tip from a deccy: Floetrol - http://www.owatroldirect.co.uk/product/floetrol/
basically helps the wet edge stay wet longer...know what you mean about losing the wet edge...have a door frame i need to sort out where i lost the wet edge and overspread it...only noticeable up close but still frustrating
Are you sure on that? It's not a oil based it's a water based acrylic so it shouldn't have the yellowing problem, in fact it would be very strange if it suffered from yellowing.
fella says non water based...i used thier non water based and it went yellow in no time
