I am a very basic skilled welder, and currently restoring an old Jaguar which requires a lot of welding. I bought a Sips Migmate 130, as I was told it was a good beginners welding machine, but here are my issues;
It is push button so having trouble setting it up to the right temp- it either burns through 1mm steel or does not penetrate enough.
The wire feed is jerky- kind of stop start regardless of what wire speed or tension you have it set on.
The weld is poor, kind of like snot, I think the term is pop corn, I can not get an even regular bead and if I do it just blows through regardless of the temp setting
On top of this it appears to have stopped working; it turns on but nothing happens when you press the trigger, you can pull the wire through the nib if you use plyers but there is nothing when you press the trigger, so either the gun has gone or the wire feed- I have no idea
If anyone can give me advice on any of the above I would be grateful
