mike os
just a little insane.....
- North Wales
Need to crimp the leads firstYes but have you checked it with a milli-ohm meter?![]()
If you have to do that it's the wrong crimp/plier combination or wrong size for the cable...I too have used the cheap ratchet type crimpers for years and never had an issue, only thing I have had to do is adjust the wee notched plate to max and they have worked well enough. What I find more problematic is some of the insulated crimp terminals themselves, some are really nasty and you have to crimp twice in slightly different places to get it to grip properly.
Nope, crap terminals. Just finished wiring up a boat and had a mixed batch of crimps that were supplied to me, some of them (same colour) needed two crimps to get them to grip securely, the others were fine.If you have to do that it's the wrong crimp/plier combination or wrong size for the cable...
Still bad practice mate - but, apart from being a sparky, my background is aerospace/militaryI have soldered many hundreds, if not thousands, of wires in cars and engine bays, even on engine looms.
Not had one failure due to vibration
That's really what I was asking but it went very much down a beaten track around the houses,past a bush and someI too have used the cheap ratchet type crimpers for years and never had an issue, only thing I have had to do is adjust the wee notched plate to max and they have worked well enough. What I find more problematic is some of the insulated crimp terminals themselves, some are really nasty and you have to crimp twice in slightly different places to get it to grip properly.
Why is it bad practice, if in practice it works perfectly fine without issue?
Ive seen more failed crimp connections than soldered ones
Also NASA recommend soldering in their version of the Western Union Splice, I think they know a thing or about critical joints
Bad practice is subjective,I'm pretty sure plumbing your house using garden hose pipe is bad practice. But it works so??
I've given up, decided to order some from various suppliers and see what's best.Time and place for solder and crimps... not really answering the op though is it ?
Splicing is very different. NASA think they know more about O rings than the manufacturer, hence ChallengerWhy is it bad practice, if in practice it works perfectly fine without issue?
Has there been a study of vibration related failures of soldered joints Vs crimped joints?
Shedloads, that's why car looms are crimped everywhere possible. Hell some of the ECU systems are now using push pin chips instead of solder joints too.
I remember watching the launch on an inside channel when we were building the new AFRTS broadcast center in Sun Valley, a sad day.Splicing is very different. NASA think they know more about O rings than the manufacturer, hence Challenger![]()
sounds a bit like using screwfix blue and red crimps or unheard of makesNope, crap terminals. Just finished wiring up a boat and had a mixed batch of crimps that were supplied to me, some of them (same colour) needed two crimps to get them to grip securely, the others were fine.
there soft copper and cables just pull out . i only use branded quality crimps and give em a good tug just to make sure there properly crimpedWhy is it bad practice, if in practice it works perfectly fine without issue?
Hosepipe I generally rated to 50 deg c maximum so would be fine for cold water but not dhw or central heating![]()
