mart
- South Yorks
The nylock nut on my lever hoist has come loose during operation. It is not surprising as I think nylocks are intended for a single use, plus the threads appear to be shot now. It has been removed a few times.
The nut always screwed on anti-clockwise,( left-handed thread). It appears to be 8mm, but I suspect the thread is not standard, as a standard 8mm nut will not screw on. It is likely to be 8mm fine or even 8mm super fine, but until I try a new nut on I won’t know, and this can cause delays. Also, the nut could even be imperial.
Here are my questions so far that I need advising on:
1: Regarding left-handed threads, is it the nut that has the left-handed thread or the bolt/shaft that the nut is being screwed on to? Or, is it both? (I`m guessing it has to be both)?
2: Is AF the same thing as imperial?
3: Does anyone know a stockist in the Sheffield or S,Yorks area etc where I could take my lever hoist, to match the thread on the shaft with the correct nut?
4: Failing this, which online retailer should I try first? I want to crack on with the job that I am using the lever hoist for and don’t want to lose too much time.
